Ensure that both the ACL and the ACE exist.
Perform this procedure to limit the number of packets that can be attached to an ACL ACE. If you want to modify the ingress bandwidth rate limiter values, you must first disable the ACE.
You can attach one policer to ACL and ACE. Every policer is independent.
enable
configure terminal
filter acl ace policer <1-2048> <1-2000> svc-rate <0–4000000000> peak-rate <8-4000000000>
You must configure both svc-rate and peak-rate.show filter acl policer <1-2048> <1-2000>
